by nigel1953
I have recently returned from a hoiday to South America. I ncurred huge charges?
I have recently returned from South America and incurred horrendous charges. I used Wifi to call back home but because i had imessage swithched on this caused the problem. Has anyone else had this problem and was there a solution with EE. Do they have a cap?
8 REPLIES 8
by Brilliant Contributor
Re: I have recently returned from a hoiday to South America. I ncurred huge char
There is no cap going outside of EU.
How did you call via Wi-Fi? WhatsApp Skype?
Or was it just a normal Wi-Fi call that some phones have.
Hi @nigel1953
It's worth speaking to EE CS but there is no guarantee they will reduce your bill. Best call them sooner rather than later.
EE Employee
Hi @nigel1953 and welcome to the community.
So I can try and help may I know have you been charged for data or for calls?
Many thanks,
Lee
by nigel1953
I logged on to local networks and used Facetime and nornal messaging
by nigel1953
calls and messages
Doesn't FaceTime cost the normal rate if used in UK so this would be classed as roaming abroad.
EE Employee
Hi @BrendonH
In order to use facetime, a data bundle would have been needed to be purchased before you are able to use this.
Many thanks,
Lee
@nigel1953  unless you purchased a data bundle you could only use FaceTime via WiFi and you’ll not be charged for this as it has nothing todo with EE.     If at anytime you was on a cellular connection and you was sending texts you’ll be charged for this  and depending on where and who was texting you you might of been charged to receive text messages also.   Any calls you made will be chargable at the roaming rate depending on where you was at the time of the call.
Where abouts where you ?
