by Lazybird999 Investigator
I have paid for 'Go further' to use in the but can not make calls or send texts
6 REPLIES 6
Re: I have paid for 'Go further' to use in the but can not make calls or send t
Did you activate roaming on your EE a/c before you left UK by texting ROAMING to 150?
Often just rebooting the phone is the simple remedy. Otherwise try logging into your MyEE account online & go to Menu / Manage Device / Roaming Abroad and also Call Abroad and Premium rate. They will show as ticked if roaming and calling abroad is activated. If they are not ticked, can you activate these settings?
Thanks for coming back to me. Roaming is activated. I can receive calls and texts but cant sent them. I can also use my 3g fine. Any ideas why I can do that but not make calls/texts
For the reason I gave above. You need the Call Abroad and Premium rate setting to be ticked.
Hi @Lazybird999
Welcome to the community. Whereabouts in the world are you?
Did activating call abroad in your My EE account fix this?
Could you try manually connecting to a different available network?
Device type Actions
iPhone Settings > Mobile Data > Network Selection > Turn off Automatic
Android Settings > More Networks > Mobile Networks > Network Operators > Tap OK
Windows Windows – Settings > Mobile Network > Network Selection > Tap on start manual search
Thank you all, I have managed to get it sorted. Your advice worked. Thanks.
Thanks! You're welcome 🙂 ! Glad I could be of assistance & it is now sorted.
