by Guyzee12
I have no coverage in malta
Please help.. i have no signal in malta.. roaming is on
by Ace Contributor
Re: I have no coverage in malta
Hi @Guyzee12,
Malta seems to having a few issues at the moment
Assuming you have roaming enabled on your account and it's worked before abroad, try turning 4G off and doing a manual network search and selecting it that way.
If that doesn't work and you've never had roaming working, your account may not be set up to allow it. Check MyEE under Manage My Device. Does it say roaming is on? You may need to contact EE to change it.
Let us know how it goes!
Hi @chistery
Thanks for taking the time to share helpful information with the community - it's great to have people sharing information that could help others, it's what the community is all about!
As a thank you from us, I’d love to treat you to dinner!
I'll send you a Private Message to get some additional details.
Many thanks,
Richard
Smiley Happy
by Guyzee12
Yeah tried that... then i clicked go mobile and left it ... took 5 minutes to establish a connection... but then it connected...
happy now.. thanks
Great news @Guyzee12
Thanks for letting us know 🙂
Have a great time!
