Highlighted
I have been blocked by 3 when roaming in Ireland
I have been blocked by 3 when roaming in Ireland.
There's no other available network.
Any idea what to do?
Highlighted
by Brilliant Contributor
Re: I have been blocked by 3 when roaming in Ireland
Hello @HarveyB ,
Welcome to the community,
Hope you are enjoying Ireland.
I would suggest you take a look here:
https://community.ee.co.uk/t5/Roaming/EE-Roaming-Help-when-abroad-with-your-EE-phone-or-device/td-p/...
Highlighted
Good Afternoon @HarveyB
I hope you're having a lovely time in Ireland.
Have you been able to look at the link provided by @Schockwave?
Are you now able to use your handset?
Katie 🙂
Highlighted
Hi, I have checked with my local EE shop in Derry N Ireland and they said that 3 seem to be blocking EE customers when they go over the boarder into Donegal Ireland and are then roaming. Do you know if there is a problem between EE and 3 in this area?
ThanksHarveyB
Sent from Yahoo Mail on Android
Highlighted
Hi @HarveyB
Do you have roaming activated in your My EE account?
Have you followed the troubleshooting and tried to connect to a different network?
Device type Actions
iPhone Settings > Mobile Data > Network Selection > Turn off Automatic
Android Settings > More Networks > Mobile Networks > Network Operators > Tap OK
Windows Windows – Settings > Mobile Network > Network Selection > Tap on start manual search
