by weesox
New Member
I have a post May 4GEE Max Plan, can I use my data as I normally do here in NZ?
I am going to New Zealand and was wondering if i can just use my data as normal as i have the post May 4GEE Max Plan?
by Ace Contributor
Re: I have a post May 4GEE Max Plan, can I use my data as I normally do here in
Hi @weesox, yes, you can, up to 15GB a month, depending on your allowance.
Please check you have roaming enabled though, text ROAMING to 150 now to check.
Enjoy NZ, I hope to make it there one day!
EE Employee
Hi @weesox and welcome to the community.
Hope you find the information provided above from @chistery to be of great help 🙂
Enjoy your trip.
Many thanks,
Lee
