by Matt25
I have a 4GEE Max plan (June 2017). Can I use my minutes, texts & data in the US
7 REPLIES 7
Re: I have a 4GEE Max plan (June 2017). Can I use my minutes, texts & data i
Yes, with your data up to 15 GB / billing month if you have more.
by Scholarly Contributor
You can actually use more than 15GB in the Max countries if you have more in your allowance.
Yes, @sully1311, you can. The 15 GB pm Fair Usage only applies within the EU.
Good Morning @Matt25.
Welcome to the community 🙂
When are you going to the US?
I can see you've had some great advice from both @XRaySpeX and @sully1311.
Let us know if you have any further questions 🙂
Jon
by Matt25
Hi Jon,
Yes we are going to the US in April for a couple of weeks. As I understand it from the advice received & EE  information I should be able to use my contracted minutes and texts as well my data allocation (25gb) - although I think that may be capped at 15gb - if I get that high with usage.
Please can you confirm that is all correct?
Kind Regards
Matt
The fair usage cap of 15gb only applies to EU countries so you can use all of your allowance in USA, Mexico, Canada, Australia and New Zealand on a post May 2017 Max Plan.
That's correct @Matt25 🙂
As @sully1311 has pointed out, the cap only applies when you are in the EU.
Just make sure roaming is set up before you go, you can do this in your MyEE Account or by getting in touch with our Mobile care team.
I hope you have a great time!
Jon
