by Wallings Investigator
I have a 4G max plan and was told it would work in the US currently it’s not
I am currently in Chicago, before I left I popped into EE shop
in London and asked if my plan would cover me in the US which I was told it would !! However does not seem to be worming for me !!
6 REPLIES 6
Re: I have a 4G max plan and was told it would work in the US currently it’s not
@Wallings  When did you take out this plan as only the newer max plans cover the US. And did you enable roaming on your account before you left the UK. ?
Hi @Wallings
Welcome to the community. 🙂
When you say it is not working, do you mean you're unable to connect to a US network?
Or are you connected, but, can't call?
Please try the troubleshooting below:-
Try re-booting your device
Try turning 4G off in ‘settings’
Perform a manual network search:-
  • iPhone – Settings > Carrier > Toggle Automatic OFF
  • Android – Settings > More Networks > Mobile Networks > Network Operators > Tap OK
  • Windows – Settings > Mobile Network > Network Selection > Tap on start manual search
Please let me know if any of that works.
Hi Chris, tried those yesterday and just now and no luck.  I have T-Mobile and 4G in the corner but no connection to internet or no iMessage / WhatsApp is going through
the odd text goes but have to select the message to force it over.
i have had the plan for a while so maybe that’s the issue but as said checked before I left that it was ok at the EE shop
i have had the plan for a while so maybe that’s the issue but as said checked before I left that it was ok at the EE shop thanks lee
Hey Chris sometime ago but maybe that’s the issue, but hence why asked before travelling cheers
Thanks for confirming, @Wallings.
It sounds like your roaming is set up, but, you're possibly on an old version of the Max plan.
I recommend getting in touch with our customer service team to see if they can swap it to a new one for you.
Let me know how you get on and enjoy the rest of your time in the USA. 🙂
