by jacqueline0 Valued Contributor
Valued Contributor
I have 4g Max plan. Can I call a UK number when both of us are in USA.
by Brilliant Contributor
Solution
Re: I have 4g Max plan. Can I call a UK number when both of us are in USA.
Hello @jacqueline0
Thank you for taking the time to post on the Community. Smiley Happy
I hope you're having a fantastic time in America. Smiley Happy
Yes, the call should be free as you have inclusive minutes to use while you're roaming in America. The message you are hearing is probably because you still have the International and Premium Calls bar enabled on you account. If you speak to customer service by Live Chat here, they'll be able to disable this for you.
I hope this helps. Smiley Very Happy
7 REPLIES 7
@jacqueline0  depending on when you got the plan.  If you got it after February 2017 yes you can.
by Ace Contributor
It also depends on what plan the person you are calling has. They may pay for the incoming call from you if it's not included in their plan.
Valued Contributor
When I call the number a message says it is not allowed. Should it be a free call?
Sent from my iPhone
Solution
Hello @jacqueline0
Try texting UNBAR to 150.
Can you receive calls, send texts & use data?
Valued Contributor
Thank you
Valued Contributor
