by a4042895
I got roaming pack but can't make call back to uk. Please help
by Ace Contributor
Re: I got roaming pack but can't make call back to uk. Please help
Did you enable roaming before you left the UK?
by a4042895
yes, i got roaming activated. i can cAll in india but can't call back uk
Sent from my iPhone
EE Employee
Good Morning @a4042895
When you're trying to make the call is it adding the correct dial code?
If you go in to Settings > Phone > Dial Assist needs to be toggled ON.
Are you hearing or seeing a message when trying to make a call to the UK?
Thanks - Karen. Smiley Happy
