by parkster
I cant text or call voicemail whilst abroad S9
Solution
Re: I cant text or call voicemail whilst abroad S9
@parkster  Login to your EE online account and under manage this device enabled call abroad and premium rate numbers, then restart the device.
Solution
by parkster
Hi Chris
I can only see my bill. No section about calling abroad
Hi there @parkster
Thanks for coming here 🙂
Are you able to receive calls?
If you're a pay monthly customer, can you check your roaming status by logging into your My EE account online > go to Menu > Manage Device > Roaming Abroad and also Call Abroad and Premium Rate >This will show as ticked if roaming is activated.
Can you activate these settings?
Leanne 🙂
