by joshkite
I cant seem to send texts or make calls from the netherlands
I am living over here for 6 months, and need it sorted.
by Star Contributor
Star Contributor
Re: I cant seem to send texts or make calls from the netherlands
Hi @joshkite
If you're a pay monthly customer, login to my ee then check if roaming is active.  Click on Mange device to see the roaming status.
Thanks,
Martyn
by joshkite
Should be complete within the next 24 hours. Thanks mate, much appreciated.
by Star Contributor
Star Contributor
@joshkite
You're welcome.
Thanks,
Martyn
You may only be abroad for at most 60 days out of any 120 to benefit from roaming.
