by ophelia1st
I cant ring out from abroad.I have been able able to before.
HI folks.I've been able to use my ee provider for a year off and on abroad same country no problems.I now can't make outgoing calls..It says operator is restricting them. I can't ring 150 from abroad and can't ring ee as thats the problem!..can't ring out.I have no other means of ringing where I am.I looked to connect manually but search  never stops actually searching..shows nothing ..I receive calls..I receive text.I tried taking sim out.I have had this for a few days.Please help x
Solution
Re: I cant ring out from abroad.I have been able able to before.
Hi @ophelia1st
Thanks for coming here 🙂
I think that you may need to activate roaming.  That is potentially the problem.
Please see our Roaming with EE - What to do if you're having problems abroad support article.
Some of the hints, tips and tricks may help to get things working for you.
If not, please log in to your MYEE and await a live chat with an advisor.
Let us know how you get on.
Richard
Solution
Hi @ophelia1st
Richard
