by KHodkinson123
New Member
I cant make or receive calls and I am abroad- help!!
I am currently in the Middle East for work. I checked that roaming was enabled before I left the UK, and it was. However, I am unable to make or recieve calls- I can't even call EE to ask for there help. Pretty urgent for me to sort this so most greatful if someone has some advice!!
by Profile closed
Not applicable
Re: I cant make or receive calls and I am abroad- help!!
Hello @KHodkinson123 have you restarted the device since arriving? Try a manual network search and selecting another roaming network if possible. Can you access this link using your devices data (not WiFi) connection:
http://add-on.ee.co.uk
