by Elaineb
I cannot make phone calls from abroad
I am currently in Spain and I cannot make calls to the UK When I try to make a call a message tells me that 'calls to this number are restricted' and to call 470 for help but this is a Spanish number. I sent a ROAMING text to 150 and the message came back that my phone is all set up for calling and on the EE app everything is enabled under roaming. Please help!
by Profile closed
Not applicable
Solution
Re: I cannot make phone calls from abroad
Hello @Elaineb have you restarted the device since landing? Try a manual network search to see if any other roaming networks are available.
Here is a link containing more information on what to do when facing problems roaming abroad:
https://community.ee.co.uk/t5/Roaming/Roaming-with-EE-What-to-do-if-you-re-having-problems-abroad/td...
by Profile closed
Not applicable
Solution
Brilliant answer @Profile closed
I hope this support article helps @Elaineb
Cheers
Richard
