Highlighted
New Member
I can’t use my phone abroad to make calls home !!!! I
Highlighted
Re: I can’t use my phone abroad to make calls home !!!! I
@George6571 : Where are you?
If you are on contract, did you activate roaming on your EE a/c before you left UK by texting ROAMING to 150?
Often just rebooting the phone is the simple remedy. Otherwise try logging into your MyEE account online & go to Menu / Manage Device / Roaming Abroad and also Call Abroad and Premium rate. They will show as ticked if roaming and calling abroad is activated. If they are not ticked, can you activate these settings?
PAYG is auto enabled for roaming. You don't need to & can't do any of the above.
Recent solutions
