by marmite89 Investigator
I can't use my pack in euro zone
The ee staff told me I will be able to use my pack just like in the Uk from the 15th June. (I'm using Pay as you go service). She said I need to do nothing, just top up before I go and use my mobile in Euro zone.
Now I'm in France and I topped up 3GB data add-on yesterday. but I can't use the data here.
I turned on the roaming and even tried to turn off/on my mobile.
Automatically the carrier is Orange F.
by Ace Contributor
Re: I can't use my pack in euro zone
@marmite89 select network manually and try with any other network.
Many Thanks
There are 4 networks like orange, Bouygues Telecom, SFR and Free.
But no one is working......:(
Hello there @marmite89
Thanks for coming here.
Can you make calls and texts?
Also what happens when you try and use the data?
Speak soon 🙂
