by Chrissiepep Investigator
I can't use my go further package in Australia
My go further package is not allowing me to make any calls from Australia
8 REPLIES 8
Re: I can't use my go further package in Australia
Hi @Chrissiepep
As per EE guide:
WHAT IS THE ROAM FURTHER PASS?
Yes.
Thanks for your message.i have paid for a Roam further pass & had a text from EE to confirm but it's not allowing me to make any calls at all.
Sent from my Huawei Mobile
Did you activate roaming on your EE a/c before you left UK by texting ROAMING to 150?
Often just rebooting the phone is the simple remedy. Otherwise try logging into your MyEE account online & go to Menu / Manage Device / Roaming Abroad and also Call Abroad and Premium rate. They will show as ticked if roaming and calling abroad is activated. If they are not ticked, can you activate these settings?
by Ace Contributor
Hi @Chrissiepep
Have you got a spend cap set? Try removing it and see if that helps, it has worked for others.
https://ee.co.uk/help/help-new/billing-usage-and-top-up/track-and-manage-your-usage/how-do-i-set-up-...
Good Morning @Chrissiepep
Following the advice you have been provided has this now resolved your problem?
Speak soon,
Katie 🙂
Thanks all! Fixed At last!! I got someone in UK to call EE to remove the
spend cap. Couldn't do it from Australia as everything was blocked!
by Ace Contributor
Thanks for updating us @Chrissiepep  Still seems odd to me why a spend cap causes this when there's no charges because of an add-on, but glad it's working.
Enjoy Australia! 🇦🇺
Thanks 😀
