by Adamcarroll92 Investigator
I can't text while I am abroad but I can receive texts
I currently have a PAYG number with EE. I switched to this to go travelling and I currently cannot send texts while abroad? I can still receive texts. How can I resolve this without called 150 as they charge me to do this from the Philippines where I currently am.
9 REPLIES 9
Re: I can't text while I am abroad but I can receive texts
Also I did speak to EE before I left to say about my plans and they assured me it was all set up and okay? Need this fixing ASAP. Thanks
@Adamcarroll92  You need credit on your account if your outside the EU to text you can only use your allowances when in the EU.
 If you do have credit on your account and your outside the EU or even if your in the EU are you putting 44  or +44 instead of the 0 at the start of the number?
Thanks for the response!
i do have credit on my account and I am just trying to send texts to contacts in my phone. I just double checked and tried to send a text making sure it's +44 but still no luck.
Hi @Adamcarroll92
Welcome to the community.
Please try the troubleshooting steps below:-
Try re-booting your device
Try turning 4G off in ‘settings’
Perform a manual network search:-
  • iPhone – Settings > Carrier > Toggle Automatic OFF
  • Android – Settings > More Networks > Mobile Networks > Network Operators > Tap OK
  • Windows – Settings > Mobile Network > Network Selection > Tap on start manual search
Please let me know if any of that works.
by Brilliant Contributor
@Adamcarroll92, I would also suggest trying 0044 instead of +44, as sometimes it does not work with +44.
Check your message centre no. for EE is +447958879879.
I have checked and it is! Thanks
Thanks for the help! Unfortunately, none of these have worked. I also tried changing it 00 44 instead of +44 and no luck.
Thanks for trying, @Adamcarroll92
As none of the advice on here seems to have worked, I can only recommend contacting our customer service team on 150 or from an alternative phone.
Enjoy the rest of your trip.
