by mdrou
I can't text when abroad
Like many other people, I cannot text since I am abroad. What should I do?
Many thanks for your reply.
Re: I can't text when abroad
Did you activate roaming on your MyEE a/c before you left? Presumably not. Having a roaming allowance does not auto enable it. You may still be able to in your online a/c under Manage Devices. If not, you will need to call EE. Use the landline nos. in my sig.
EE Employee
Welcome to the Community @mdrou
What phone are you using?
Can you receive calls and texts ok?
Can you make calls or are both outgoing calls and texts affected?
Thanks - Karen. Smiley Happy
by mdrou
Thank you for your reply.
Yes indeed I didn't do anything to activate roaming before leaving. So it must not be activated... I will know next time!
EE Employee
Hi @mrdrou
If you're a personal EE customer you can use the live chat option on the get in touch pages.
They'll be able to help get you up and running.
There's some really good info on our Roaming sticky topic that may help you in future.
