by Debs06
New Member
I can't send sms texts from Italy. How do I sort this problem?
Re: I can't send sms texts from Italy. How do I sort this problem?
Good afternoon @Debs06
Thank you for coming to see us all the way from Italy 🙂
Is it just SMS or is it calls you are having difficulty with as well?
Did you make sure roaming was set up before you went away?
I would invite you to please have a look at our Roaming with EE - What to do if you're having problems abroad post.
This should hopefully give you all the information you need.
Richard
