by mszypkowski Investigator
I can't phone or text in germany
Came to Germany from UK with EE Samsung S7 and I have a 2 year contract and it says I should be able to text and call for free along with 500 MB of data roaming. Only data roaming works and I can receive texts and call but messages and calls don't go through at all. Is there any solution to this, other than restarting your phone as I've done that 5 times already with no luck?
Solution
Re: I can't phone or text in germany
@mszypkowski: Did you activate roaming on your MyEE a/c before you left? Presumably not. Having a roaming allowance does not auto enable it. You may still be able to in your online a/c under Manage Devices. If not, you will need to call EE. Use the landline nos. in my sig.
Can't text in germany
Read more
Texting and calling
Solution
EE Employee
Welcome to the Community @mszypkowski
It sounds like your International bar may still be active.
Let me know if you're able to activate it in My EE as per @XRaySpeX 's advice.
Thanks - Karen. Smiley Happy
Yes that worked. It took 24 hours and a couple of restarts but after I
activated roaming online i can text abroad again. 🙂 thank you so much!
Will i need to deactivate it when I return home?
You're welcome. Glad I could be of assistance.
No, it should now be activated for whenever you go abroad in future.
