by Tybellz
I can’t make phone calls in the Netherlands
I’ve sent a text ‘roaming’ text to 150, rebooted my phone and set it to roaming in my settings menu. Nothing is working!
Re: I can’t make phone calls in the Netherlands
@Tybellz  Login to your online EE account and enable call abroad and premium rate numbers.  Then reboot the device.
Hi there @Tybellz
Welcome to the community.
If you can follow the advice from @Chris_B and log into your My EE account online
Then go to Menu > Manage Device > Call Abroad and Premium Rate.
This should show as ticked for you, can you activate this?
Leanne 🙂
