by ingyluv
I can't make outgoing calls in Spain?
International roaming appear to be enabled on my phone but I need a pin to change it?
by Ace Contributor
Re: I can't make outgoing calls in Spain?
HI,
@ingyluv
Try to call on number international format, 00447 or +447***
If you done that then Have you get this prompt response,  call to this number barred from this phone ? Then you need to remove your international call barring via live chat with ee customer advisor.
Open this page http://ee.co.uk/help/get-in-touch
Live chat can be found underneath +EE.
EE Employee
Hi @inglyluv and welcome to the community.
So I can try and help, please may I get you to perform a manual network search and choose a network other than what you are on.
Please also can I get you to try and dial a friend or family member using format of 00447*********, did this work?
Also, please let me know If you are using an EE personal or business account as I may be able to assist with our live chat service?
Many thanks,
Lee
