by HS68
I can’t make calls
by Brilliant Contributor
Re: I can’t make calls
by HS68
Why can’t I make calls from my iPhone?
Re: Why can’t I make calls from my iPhone?
Hi @HS68
Log into your on line account and then Menu - Manage Device - make sure you have activated roaming and international calls.
Or
From the MyEE app Current Usage - Controls - activate use phone abroad and make international and premium calls
