by Smithy73
I can't make calls from greece?, have tried everything!
I can use data, recieve calls + texts, but can not make calls or send texts in greece have tried everything via device and ee account and all online device!
Re: I can't make calls from greece?, have tried everything!
@Smithy73 : If on contract, did you activate roaming on your EE a/c before you left UK by texting ROAMING to 150?
Often just rebooting the phone is the simple remedy. Otherwise try logging into your MyEE account online & go to Menu / Manage Device / Roaming Abroad and also Call Abroad and Premium rate. They will show as ticked if roaming and calling abroad is activated. If they are not ticked, can you activate these settings?
PAYG is auto enabled for roaming. You don't & can't do the above.
Hi @Smithy73
Welcome to the community, I hope you're having a brilliant time in Greece. 🙂
Sounds like it could be what @XRaySpeX said. Were you able to set up your roaming and international calls through your My EE account?
You could also try manually selecting a different network:
Device type Actions
iPhone Settings > Mobile Data > Network Selection > Turn off Automatic
Android Settings > More Networks > Mobile Networks > Network Operators > Tap OK
Windows Windows – Settings > Mobile Network > Network Selection > Tap on start manual search
Let me know how you're getting on.
by Smithy73
Hi, thankyou for reply, have looked at this, the only box which is blocked
is the last one, international and premium, which i can't manually unblock.
Any further advice would be appreciated.
You'll need to call EE to unblock it.
Hi there @Smithy73
Thanks for coming back and letting us know.
I have sent you a private message on here for some details.
Speak soon 🙂
