by Collinsreal25
I can’t make calls from Germany to uk
I can’t make calls or text from Germany to uk
EE Employee
Re: I can’t make calls from Germany to uk
Hi @Collinsreal25 and welcome to the community.
So I can try and help, please may I get you to perform a manual network search and choose a network other than what you are on.
Please also can I get you to try and dial a friend or family member using format of 00447********* and try using data.
Did this work?
Many thanks,
Lee
