by LorraineH
I can't get a network in Spain
I am in Spain but I cant connect to a network
Re: I can't get a network in Spain
@LorraineH: Did you activate roaming on your MyEE a/c before you left? Presumably not. Having a roaming allowance does not auto enable it. You may still be able to in your online a/c under Manage Devices. If not, you will need to call EE. Use the landline nos. in my sig.
@LorraineH  Have you tried restarting the device?
Hi @LorraineH
Welcome to the community.
As well as the brilliant advice above, I recommend trying to connect manually to a Spanish network:
Device type Steps
Apple Settings > Carrier > Toggle Automatic OFF
Android Settings > More Networks > Mobile Networks > Network Operators > Tap OK
Windows Settings > Mobile Network > Network Selection > Tap on start manual search
Please let us know what happens.
Recent solutions
