by MichaelHann
I can't call the UK from the US
I am in the US, but can't call the UK. I have the Travel roaming pack at £4.80 a day, but can't call home. How can get this sorted? Thanks.
Re: I can't call the UK from the US
Did you activate roaming on your MyEE a/c before you left? Presumably not. Having a roaming allowance does not auto enable it. You may still be able to in your online a/c under Manage Devices. If not, you will need to call EE. Use the landline nos. in my sig.
by Ace Contributor
Also, the £4.80 add-on is just for data?
It's the World Select Talk and Text add-on for £6 that includes calls?
Hello there @MichaelHann
Can you receive calls and texts?
Are you with us on pay monthly or pay as you go?
Thanks, Leanne.
