by Vikkiwoodison Investigator
I can't call the UK from abroad even though I have international roaming.
I can't call UK from abroad even though I have international roaming. My phone settings say internatonal calls disabled and then it asks me for a pin code. I have tried 0000 and 1111 and 1919 from searching on forums but nothing has worked?
6 REPLIES 6
by Ace Contributor
Re: I can't call the UK from abroad even though I have international roaming.
HI,
@Vikkiwoodison
You need to Get in Touch with  - EE customer service,
You can do this via live chat opening get in touch page underneath +EE where you can live chat with advisor and ask to remove international call barring.
Many Thanks
Hi @Vikkiwoodison
Welcome to community 🙂
Let us know if the great help given by @tahirmian helps get everything sorted for you.
Richard
Unfortunately the advice given (basically switch it off and back on again) didn't work.  I am pretty convinced I need to enable international calling in my phone settings but need a pin to do this. Can anyone help?? My phone's a Samsung. Thanks.
by Ace Contributor
@tahirmian wrote:
HI,
@Vikkiwoodison
Many Thanks
Please do chat again with adviser and ask them to remove your international call barring.
Live chat team will be available 8:00 am UK time.
Many Thanks
I will try again. I did ask for yhis but was told it couldn't be done! I guess you just have to be lucky depending on which adviser you get!
Morning @Vikkiwoodison.
The advice from @tahirmian is correct this does need to be removed for you.
Let me know how you get on today after speaking to our technical chat team 🙂
Thanks, Leanne.
