by Jon65 Contributor
I can't call home from Europe, though I have a 4Gee contact. Help please!
I've recently moved to EE, on a 4Gee contract. I'm in Europe on holiday, and unable to make a call home, although data roaming & texts seem to work. I can't call EE, so this is a bit Catch 22! What is my best plan?
Thanks, Jon
24 REPLIES 24
by Profile closed
Not applicable
Re: I can't call home from Europe, though I have a 4Gee contact. Help please!
Hello @Jon65 try restarting your phone then trying to make a call again. You can also try a manual network search in the phones settings app and selecting another network once the list of available networks have loaded to see if an alternative one works. Here is a link to more information on roaming with EE. :):
https://explore.ee.co.uk/roaming
Hi, I've tried switching it off & on again 🙄, also I have the same problem with different messages when the network is Orange or Movistar. Looking back through the forum, it seems like I'm not the only person to have this problem. Maybe something wrong in the setup of my contract?
by Profile closed
Not applicable
Hello @Jon65 thank you for conforming. In that case customer service may need to have a look at your account to make sure roaming has been enabled correctly. You can contact them from any phone on +447953 966 250 (lines open at 8am) or if you are a personal pay monthly customer on an EE plan you can also login to MYEE online and click the popup box when available to speak to live chat. 🙂
Calling them on a phone that won't make calls is going to be tricky... I'll try the online help but I must say I'm pretty disappointed to be having to spend my time trying to figure this out. Thanks for your help anyway.
I've just tried texting Roaming to 150, but the text won't send!
by Profile closed
Not applicable
You're welcome @Jon65 I am sorry I could not give you a more helpful answer. You can also try a network reset by tapping settings>general>reset>reset network settings for iOS or settings>back up & reset for Android (you will have to re-enter wifi passwords). If this still does not work then hopefully customer service can resolve this for you soon. Let me know how you get on if you have the time. 🙂
@Jon65  Did you call customer services to have roaming enabled before you left the uk ?  Or did you text ROAMING to 150 before you left the uk ?
You tariff allows  you to use your allowance when abroad it doesn't mean roaming is enabled these are not the same thing.
@Karen_C @James_B. Can one of you please help with this. Thanks
Hi @Jon65,
Welcome to the EE Community.
I've sent you a private message with a link to chat with customer service online.
They'll make sure roaming is activated on your account.
Hope this helps. Smiley Happy
Thanks James. I had the chat early on today, it seems that there was something set up incorrectly on my account. That's sorted now, but I was told it may take 24 hours to activate - frustrating as we go home on Thursday.
Cheers, Jon
by Profile closed
Not applicable
Good to hear this has now all been set up correctly @Jon65 thank you for coming back to let us know. Apologies for the inconvenience, this is a one time step so now it has been enabled unless you cancel your line and take out a new one you should not encounter this again.
Come back to the community anytime if there is anything else you would like to discuss/share. 🙂
We're at 23 hours and still no calls home - EE are holding me to the 24 hours! I'm switching off regularly, just in case...
EE Employee
Good Morning @Jon65
Sorry to hear it's still not working!
Do you get a message when you try and make an outgoing call?
What device are you using?
Thanks - Karen. Smiley Happy
Hi Karen,
i get 'this option is not available, please contact customer support '
It's an iPhone 7+.
thanks, Jon
EE Employee
Hi @Jon65
Have you tried doing a manual network search in Settings > Carrier?
If not try this and try connecting to a different network.
Also if you go to Settings > Phone > is Dial Assist toggled On?
Dial assist is on. I only have 2 networks available here, Orange and Movistar. I've tried with both, and neither makes any difference.
It's pretty much 24 hours now.
I've tried different networks - no joy.
dial assist is on.
EE Employee
Hi @Jon65
Thanks for trying!
Can you receive incoming calls ok?
It's a strange error message, as normally if your International Bar is active you would hear - "outgoing calls are barred"
Incoming calls seem to work okay.
EE Employee
Hi Jon,
One last thing to try!!
Settings > Mobile Data > Mobile Data Options > Enable 4G > Tick Off for me.
Then try making a call.
I've got everything crossed!
