by Sampoole1
New Member
I can't access internet abroad
I am in Thialand and despite having my mobile data turned on am unable to access the internet.
Sam
by Ace Contributor
Re: I can't access internet abroad
Hello @Sampoole1 have you got mobile data roaming turned on as well as mobile data? Did you enable roaming at least 24-48hrs before traveling:
https://community.ee.co.uk/t5/Roaming/EE-roaming-Getting-ready-to-use-your-phone-abroad/td-p/532570
Is there another network you can try when you perform a manual network search? More information on what to do when havibg problems roaming abroad:
https://community.ee.co.uk/t5/Roaming/Roaming-with-EE-What-to-do-if-you-re-having-problems-abroad/td...
Hello there @Sampoole1
Welcome to the community.
Are you able to make and receive calls?
Also, are you with us on pay as you go or pay monthly?
Hope you’re having a great time 🙂
