by Krizzie Investigator
I am unable to make calls from Greece although I have ruth minutes
by Profile closed
Not applicable
Solution
Re: I am unable to make calls from Greece although I have ruth minutes
Hello @Krizzie has roaming been enabled on your account? You can check by logging in to MYEE online and navigating to MYEE>Manage device. If it has been then try restarting your phone and/or a manual network search to see what local networks are available. Here is a link containing more information on using your phone abroad. :):
http://ee.co.uk/help/add-ons-benefits-and-plans/call-or-going-abroad/roaming-using-your-phone-abroad
6 REPLIES 6
I mean EU minutes
by Profile closed
Not applicable
Solution
by Ace Contributor
@Krizzie
Have your roaming?
You need to roaming on your phone before left UK.
Many Thanks
Thank you. I had not enabled before I left but seem to have been able to do it now.
by Profile closed
Not applicable
You are welcome @Krizzie come back to the community anytime if there is anything else you would like to know. 🙂
EE Employee
