by davyhall16
I am travelling to America, will my phone work as normal. What fees apply?
I'm travelling to America, will my phone work as normal? What fees apply?
by Ace Contributor
Re: I am travelling to America, will my phone work as normal. What fees apply?
What plan are you on?
http://ee.co.uk/help/add-ons-benefits-and-plans/call-or-going-abroad/roaming-costs/countries/usa
Make sure you have roaming enabled before you leave, text ROAMING to 150 now to check.
Hello there @davyhall16
If you are on a 4GEE Max Plan that has started after the 10 May 2017 you will be able to use your allowances within America.
For full information see our using your EE allowance when abroad post>
If you don't have one of these plans see our charges for using your phone within America.
As @chistery has advised make sure you get in touch with us to make sure you are all set up to use your phone abroad.
Hope you have an amazing time 🙂
