by Bizdav30
I am travelling from sws Scotland to the Isle of Man, can I use EE service there
by Ace Contributor
Solution
Re: I am travelling from sws Scotland to the Isle of Man, can I use EE service t
Please see the link below for more info:
https://explore.ee.co.uk/roaming/ee/isle-of-man
Also, before your departure, check out the following link to make sure your account is set up for roaming:
https://community.ee.co.uk/t5/Roaming/EE-Roaming-Getting-ready-to-use-your-phone-abroad/td-p/532570
W
by Ace Contributor
Solution
W
by Bizdav30
Thank you
