by cornishtales Contributor
I am in italy and i have roaming but i cannot ring any numbet in my contacts. It
The number immediately ends the call
EE Employee
Solution
Re: I am in italy and i have roaming but i cannot ring any numbet in my contacts
Hi and welcome to the community @cornishtales
So I can try and help, please may I get you to perform a manual network search and choose a network other than what you are on.
iPhone: Go to Settings > Carrier and turn off Automatic. Wait until available networks appear, which might take two minutes. Tap the carrier that you want.
Android: Open the Settings menu >Tap More > Mobile Networks > Carrier and turn off Automatic. Wait until available networks appear, which might take two minutes. Tap the carrier that you want
Please, also can I get you to try and dial a friend or family member using the format of 00447********* and try using data.
Did this work?
Are you able to receive calls/texts?
Many thanks,
Lee
EE Employee
Solution
Did this work?
Many thanks,
Lee
Success. Thank you Lee.
Great news @cornishtales
Have a lovely time in Italy 🙂
