by Cally2
I am in Turkey and cannot send texts or make outgoing calls as it says they are
What do I do when I am in Turkey and cannot send outgoing texts or calls as it says the are barred. EE help is useless. What do I do?
by Cally2
Re: I am in Turkey and cannot send texts or make outgoing calls as it says they
Hi @Cally2
Log into your on line account and then Menu - Manage Device - make sure you have activated roaming and international calls.
Or
From the MyEE app Current Usage - Controls - activate use phone abroad and make international and premium calls
Hi @Cally2
Welcome to the community. I hope you're having a brilliant time in Turkey so far. 🙂
Did you manage to check if roaming and calling abroad are activated in your My EE account?
If they're both active and you're still having problems, please try manually selecting a different network:
Device type Actions
iPhone Settings > Mobile Data > Network Selection > Turn off Automatic
Android Settings > More Networks > Mobile Networks > Network Operators > Tap OK
Windows Settings > Mobile Network > Network Selection > Tap on start manual search
