by arekszewc201684
New Member
I am in Poland now Why I can't make calls out to UK numbers?
I am in Poland now and I ccan'tmama calls out to UK numbers also iIcan't rerecei calls in from  UK numbers??
by Brilliant Contributor
Re: I am in Poland now Why I can't make calls out to UK numbers?
Did you see up roaming before leaving the UK?
Sign into MyEE and wait for the live chat box to pop up.
Ask them to activate roaming.
Hi @arekszewc201684
Welcome to the community.
Try re-booting your device
Try turning 4G off in ‘settings’
Perform a manual network search:-
  • iPhone – Settings > Carrier > Toggle Automatic OFF
  • Android – Settings > More Networks > Mobile Networks > Network Operators > Tap OK
  • Windows – Settings > Mobile Network > Network Selection > Tap on start manual search
Please let me know if any of that works.
