by clarabelea Investigator
I am in Malaysia and have signed up for the travel data pack but its not working
I have turned my phone in and off, tried different networks etc but only able to access messages, email etc via WiFi but my phone is trying to connect so data usage is showing low data - what I don’t want is to be charge the daily rate when I am not actually getting to use it!
Any advice? I have iPhone 7
Re: I am in Malaysia and have signed up for the travel data pack but its not wor
Hi @clarabelea
Welcome to the community, I hope you're having a lovely time in Malaysia. 🙂
Just to put your mind at ease, if you're on an EE contract, you won't be charged per MB if you were to use the full allowance of data. You would be prompted to purchase another data add-on. 🙂
Is your problem that you are unable to use data because of signal strength?
If so, please try the troubleshooting steps below:-
Try re-booting your device
Try turning 4G off in ‘settings’
Perform a manual network search:-
  • iPhone – Settings > Carrier > Toggle Automatic OFF
  • Android – Settings > More Networks > Mobile Networks > Network Operators > Tap OK
  • Windows – Settings > Mobile Network > Network Selection > Tap on start manual search
Look forward to hearing from you.
Hi Chris Thank you for your reply but that is my concern as I have text to purchase a data add on pack but it isn’t accessing anything although using small amounts trying to (deal is if I use it I get charged for each day I use it) but it isn’t losing anything - perhaps strength etc but how can I tell? It suggests good strength but that wheel of doom keeps spinning and nothing happens. I have tried all that you have suggested but still no joy plus it’s hard when you don’t have internet to try to sort it! Any other thoughts? Clare
Hi @clarabelea
Thanks for getting back to @Christopher_G
He's not in until a little later on, so I've picked this up to try and help.
Are you in an area where you have signal?
The wheel keeping spinning suggests you perhaps aren't.
Can you use calls and texts OK?
Richard
It’s so hard to tell as I have only received texts when in WiFi but have had a voicemail which suggests it didn’t come through as a call - I have asked other people locally who seem to have good internet. I have tried all the suggested things ie manually connect to different service providers, turn of 4G etc - if I had known it was going to be this tricky I would have got a separate sim and phone but I believed that every time anywhere would work if I paid for roaming.
Any advice on the the best way to proceed welcome
I've sent you a private message, @clarabelea.
Please take a look and get back to me.
I'll do my best to get you some help.
Chris 🙂
