by StephenPotts
New Member
I am in Italy. How do I unblock outgoing calls?
I am Italy. Whenever I try to make a call I get an automated message saying outgoing calls are blocked. I have tried to manually select a network but none of the carriers that I have access to (TIM and WIND) work. Any suggestions? Thanks
Re: I am in Italy. How do I unblock outgoing calls?
Hi @StephenPotts
Try logging in to your online account and activating roaming and international calls.
Also make sure roaming is activated on your phone under network settings.
Hi @StephenPotts
Welcome to the community, I hope you're having a brilliant time in Italy so far. 😄
I recommend logging into your My EE account and checking your roaming and international calling status, as suggested by @Northerner. 🙂
Find it under Menu > Manage Device
Let us know how you're getting on.
