Highlighted
by Investigator
I am in Barbados and my iPhone won’t receive calls
I am on holiday in Barbados and my iPhone isn’t reveiving calls. I have tried turning off and on and have also tried turning Airplane Mode on and off. Do not disturb is also off.
can anyone help?
Highlighted
Solution
Re: I am in Barbados and my iPhone won’t receive calls
Hi there @stephenwoolfe
Thanks for coming back to us.
Can you try and select another network;
Go to Settings > Mobile Data > Network Selection > Turn off Automatic and select a different network.
Does this work for you?
Leanne 🙂
6 REPLIES 6
Highlighted
Can you receive texts?
Are you able to make calls?
Hope you're having a great time 🙂
Highlighted
by Ace Contributor
@stephenwoolfe Have you checked the settings in your device to ensure roaming is enabled too?
Highlighted
by Investigator
Thanks for your help.
i can make calls, send and receive emails and send and receive texts.
Roaming is on. I have turned my iPhone off and then on again. Do not disturb is off.
So I’m not sure what else I can try.
any help would be appreciated
Stephen
Highlighted
Solution
Leanne 🙂
Highlighted
by Investigator
Leanne
Many thanks - that solved the problem!
Appreciated
Stephen
Highlighted
Great to hear @stephenwoolfe
Thanks for letting us know, have an amazing time in Barbados.
Katie 🙂
Recent solutions
