by Pups Investigator
I am going to Funchal In Madeira, do I need to do anything to my phone as I had
Solution
Re: I am going to Funchal In Madeira, do I need to do anything to my phone as I
Morning @Pups
I can see you have had some great advice about using your phone in Madeira.
You will be able to use your inclusive minutes, texts and up to 15GB of data when in Madeira as well 🙂
Hope you have a lovely time.
Hi @Pups
Text ROAMING to 150 and ensure your service is activated. I think you should be able to roam as at home (max 15GB ) as isn't Madeira classes as Portugal?
@Pups :
  • If you are on contract you need to do as suggested above.
  • If you are on PAYG, you need do nowt. PAYG is always enabled for roaming.
Solution
Morning @Pups
