by Al13
I am going to Florida for 2 weeks what cheapest way to use my phone for sat nav
Solution
Re: I am going to Florida for 2 weeks what cheapest way to use my phone for sat
@Al13   You can use up to 15GB of data per month if you on a max plan in the US as your tariff allows you to use your device in the US.
just make sure you text ROAMING to 150 before you leave the UK, you can do this now if you wish..
@Al13   Text RO AMERICA to 150 to see what your options are.   There is no cheap way to use data when roaming apart from purchasing add ons.
Hi @Al13,
Welcome to the community. 🙂
Which plan are you using?
by Al13
Hi I am on 4gee max plan
Solution
