by nickPitto
New Member
I am abroad in the EU and can’t connect to any carrier for data or calls?
Re: I am abroad in the EU and can’t connect to any carrier for data or calls?
If you are on contract, did you activate roaming on your EE a/c before you left UK by texting ROAMING to 150?
Often just rebooting the phone is the simple remedy. Otherwise try logging into your MyEE account online & go to Menu / Manage Device / Roaming Abroad and also Call Abroad and Premium rate. They will show as ticked if roaming and calling abroad is activated. If they are not ticked, can you activate these settings?
PAYG is auto enabled for roaming. You don't need to & can't do any of the above.
Hi @nickPitto
Thanks for posting on the community 🙂
If you can follow @XRaySpeX advice and let us know if this works for you?
Speak soon 🙂
