by debo Investigator
I am abroad and have no service. I didn't receive a text from 150.
I am in Kosovo and have no service. I didn't receive a text from 150.
When I go to carrier settings and change to manual I can select a service provider but I still can't make calls or texts.
I have tried to create a My EE account to check my data roaming settings but it says my number isn't recognised?
I have previously used my phone abroad without many issues.
I have tried switching the phone of and on again and rebotting the phone and I still have the same problem.
Does anyone have a solution or another thing to try?
10 REPLIES 10
Re: I am abroad and have no service. I didn't receive a text from 150.
Hi @debo
If you have an iPhone then try resetting your network settings.
Is your account on PAYG or pay monthly.
Hi @debo
Welcome to the community.
Does it show a signal when you manually select a network?
Thanks Northener, resesting network settings didn't work. It's still saying no service.
I am pay monthly, sim only (3G)
Hi, it sometimes shows a very low signal but when I try make a call, the call fails and I lose signal.
I know there is a stronger signal on the manually selected network as a colleague (on o2) is using the name network here.
Hi @debo
3G? are you on EE, T-Mobile or Orange?
Also make sure roaming is activated on your phone under settings..
Other than the above you will need to speak to CS.
Good Morning @debo
Thanks for coming back to us.
Are you able to receive any calls?
Speak soon, Leanne.
Yes 3G (long story). EE via T Mobile.
Yes thanks Data Roaming is on and still no joy.
I managed to speak to CS/technical who couldn't resolve it despite trying for 30 mins and have transfered it 'up'. Still waiting a response... 😕
Thanks for your help
I see @debo
Let me know how it goes when they get back to you
Hope you get this sorted.
@Leanne_T wrote:
Good Morning @debo
Speak soon, Leanne.
Well, I have no service so it's doubtful any calls can get through either. When I've had a very small amount of signal I've not received any calls but not tested it specifically
Thanks for coming back to me @debo
I have sent you a private message on here to get some further information.
Thanks, Leanne.
