by Brilliant Contributor
Hurricane Dorian: Free Calls, Texts & Data (The Bahamas)
If you’re affected by Hurricane Dorian, EE have made calls, texts and data used in The Bahamas free-of-charge for customers between September 1st and 6th (inclusive).
EE are continuing to closely monitor the hurricane and will continue to help customers in the region wherever they can.
EE have also made calls from the UK into The Bahamas free, so you can check on your loved ones without incurring additional charges.
Please be aware that mobile signal in the area may be severely affected by damage to local networks and equipment.
by arul
New Member
Re: Hurricane Dorian: Free Calls, Texts & Data (The Bahamas)
Hi
I need to get free sim card
by Ace Contributor
Hi @arul
Welcome to the EE Community,
you can get a free SIM by visiting this link
https://shop.ee.co.uk/sim-only/pay-as-you-go-phones
Thanks,
David.
