by Seymour24
New Member
How to use ur phone abroad
Re: How to use ur phone abroad
@Seymour24 : If you are on contract, remember to text ROAMING to 150 before you leave to check roaming is enabled on your account.
If you're going to the EU, you may use your usual allowances there with up to 15 GB data per billing month if you have more.
Hi @Seymour24
Log into your online account and then menu - Manage device, make sure you have activated roaming and international calls.
Or
From the MyEE app current usage - controls, activate use phone abroad and make international and premium calls
Hi @Seymour24.
I see you've had some great advice already 🙂
Where are you planning on using your phone?
Jon
