by Kwagg Investigator
How to use my phone in America
Re: How to use my phone in America
Hi @Kwagg
It depends on what tariff you have or if you are PAYG. Also if roaming is activated on your account (text ROAMING to 150).
Hi thanks,
Am on sim only deal..
Karen
Sent from my iPhone
by Scholarly Contributor
Could you go onto the MyEE app if you have it > Plan & Add-Ons > See Your Plan and reply with the name on your plan and the description underneath yet.
Basically if you've got a Sim Only Max Plan (not available anymore) taken out after 10 May 2017 you'll have roaming in the US included.
Hi @Kwagg.
Welcome to the community.
I see you've had some great advice from @Northerner, and @sully1311 has asked a very valid question.
Further to this, we have a great Roaming Page which explains the cost of using your phone in the USA 🙂
Jon
