by weathermum79 Investigator
How to set up roaming while already abroad
I am already abroad and have been unable to make calls or texts. How do I set up roaming? I can't text to 150 as have no service.
Re: How can I set up roaming when I'm already abroad?
I have the same issue. Please can you help?
by Ace Contributor
Re: How to set up roaming while already abroad
Hi @weathermum79 you can turn your roaming on via my EE app or Web account.
How?
On my account, it all looks fine but I haven't been able to connect to a
service since arriving on Saturday.
Hi there @weathermum79
Welcome to the community 🙂
I hope you're having a fantastic holiday so far.
You can ensure roaming is enabled on your My EE account by following these instructions:
Login to your My EE account > Menu > Manage Device > Roaming Abroad > This will show as ticked if roaming is active.
If this is already active I would recommend a manual network selection, please follow these steps to completed this:
iPhone – Settings > Mobile Data > Network Selection > Turn off Automatic
Android – Settings > More Networks > Mobile Networks > Network Operators > Tap OK
Windows – Settings > Mobile Network > Network Selection > Tap on start manual search
Finally if this does not resolve, I would ask you to try switch 4G off
Speak soon,
Katie 🙂
I have responded to your post in this thread :).
Katie
