by Pip31
New Member
How to set up data roaming while abroad
I am currently abroad and forgot to set up my roaming before, how do I set it up now while abroad?
Solution
Re: How to set up data roaming while abroad
Hi @Pip31
Log into your online account and then menu - Manage device, make sure you have activated roaming and international calls.
Or
From the MyEE app current usage - controls, activate use phone abroad and make international and premium calls
Solution
Hi @Pip31
Or
