by Jonjon1 Investigator
How to remove call barring
Hi im abroad and need to remove the call barring on my samsung s8.
Please can you help?
9 REPLIES 9
Re: How to remove call barring
Can someone please send me a pin code to un barred my international calls
pleeease?
@Jonjon1: In your MyEE under Manage Device allow Call Abroad & Premium Rate. If it won't let you you will need to call EE.
Hi @Jonjon1,
Welcome to the EE Community.
Did @XRaySpeX's advice help you remove the bar in My EE?
No i need the pin to remove the barring still. Thank you
Hi @Jonjon1,
It's not possible to remove the call bar within your phone's settings.
What happened when you tried to remove the bar in My EE?
It asked me a code to remove the barring.
I tried but its still on the barring mode
Hi @Jonjon1,
When you log in to your online account and select 'Manage device' from the menu, do you see an option to toggle on 'roaming abroad' or 'Call abroad and premium rate'?
No one will send you a PIN. It's not possible to remove the call bar yourself within your phone's settings. You either remove it yourself in your MyEE if it will let you as we keep advising you or you phone EE.
